What's the deal with miata AC vents? They drive me crazy!!! they always fall down as soon as I position them! Does anyone have any suggestions to keep them in place so I can atleast get some benefit from having a good ac compressor?::Rant::
Put them where you want them and then push them in. That should hold them in place.
Replace the felt ring.
A strip of black tape across the top of the vent will help. Fish a piece of thin rope thru the vent. In one side and out the other. Pull straight out.
I used little circular felt stickers, from the crafts department at wal-mart. They work better than tape.
And if you put the felt on top of the ball, I suppose you probably just felt yourself up...
Like they said with the string and pull.
I also have placed credit cards on each side, pushed in about 1/4 inch, and they fell out.
Bring this one back.
I'm trying to fix my lazy vents. The center 2 came out with just a slight tug. I used quite a bit of force on the driver side vent and it will not come out. (I know I'm going to regret this) Should I just tug it real hard.
I say tug away if it makes you happy, as far as removing the vents, I have never done that.
Miata.net to the rescue: Tighten your vents!
I pulled my vents (center ones only, those are the only ones I could pull out) and applied some sticky-back foam to the eyeballs. Now they stay where I want them!
