Does anyone have the springs adjuster for GC coilover that I can borrow this weekend? Preferably in Arlington area. thanks,
you should be able to loosen the allen and turn it by hand.
I tried but it was too hard since I try to raise the car.
Did you jack the car off the ground first?
I've always been able to twist my perch when jacked off the ground. Make sure to jack off both the left and right because you don't want the rigid swaybar binding when twisting your perch by hand. You may want to use a glove because you never know how much dirt your undercarriage has seen. Just because it looks clean, doesn't mean it is.
I did jack the car off the ground but only one side. I will try both side and see.
