Changing the diff and transmission oils
So I bought the oils I want, got some ramps, already had a jack and some jackstands, go to do this seemingly easy task.
Can't get either of the fill plugs out. I've used PBlaster, let it soak a day, tried again. No luck. For the diff I've got a long heavy duty 1/2 ratchet and the correct socket. I think I might get this one with a little more work and luck.
For the tranny the fill plug bolt seems to be square? I don't know if someone tried before and destroyed the head, or it just came that way. A 14mm box end wrench fits it, but I'm not sure I could get a long enough wrench (or pipe) on it without having the car on a full lift. I would guess this bolt is original, as there's a bit of paint on it that continues unbroken onto the tranny housing. 88,000 miles can sure make things tough to take apart.
Any recommendations? Otherwise I'm going to have to find a shop to do the change for me, which would be a real pity seeing how I've already bought everything to do it... well, minus air tools.
Maybe I just need to work out more...
