More Neg. Front Camber Than Rear?
Anybody read on M.Net the thread titled "More Negative Camber==More G's???"? In it, several guys are promoting more negative camber in the front than the rear. This is certainly opposite from everything I've ever heard. Seems that conventional wisdom is more in rear than front. Anyway, have any of you guys tried this for autocross purposes, or on the street?
Re: More Neg. Front Camber Than Rear?
As they say search is your friend.
http://forum.miata.net/cgi-bin/ultim...c;f=4;t=002622
I would lean toward proven winners testing like Andy Hollis. He does testing in a logical manner. Your car is not like his as far as weight and preparation. He is using around -1 degree all around but he has better shocks. I don't know if you have changed the bushing yet? In a car that was 12 years old I would say that should be one of the first things to do other wise you are compromising more expensive parts ability to work at their maximum. Andy does stress weight does make a difference in the Miata.
So I would say in a car that is near 50/50 weight balanced and Lowered that a lot more camber in the front than the rear would not be the optimum for the "complete traction circle". There is more than just turning involved in autocrossing. Quantified testing and a pyrometer will give you much better results than "seat of the pants" guesses.
Speaking of "seat of the pants" testing.... Did you make any sway bar changes for the TMS road course event? What Happened?
