Linkie
Perhaps?
Linkie
Perhaps?
Yup. You'll just have to be real careful putting them on since the hub bore on the wheel is a bit larger than the hub on the car.
If the bolt pattern is 4 x 100 and depending on offset, yes. Have you been to Mazda Heaven lately? I got a set of OEM wheels there cheap!
What's is the offset??
I believe it's 44... but I'll ask the seller.
Most wheels aren't *really* hubcentric anyway. You should always use a good tapered lug nut and tighten them with the wheel in the air. It'll be just fine. 44mm offset might put them a ways in from the fenders tho.Quote:
They are a 45mm offset... perhaps these and some 10mm spacers?
the only cars i have noticed so far that depend on the hub is bmw's because they have threaded studs instead of lug nut's so it has to sit right before you can crank it tight.
