Very sad news from the weekend :(
That's terrible. I would be very sad if someone I knew on this forum had crashed that bad. I read through the S2k thread and found this near the end:
QUOTE (robrob @ Nov 11 2008, 11:22 PM)
Four of Cale's friends from Hagerstown flew a helicopter down to Summit Point today and I took them out to Turn 1 and we viewed Cale's car. We spent about 45 minutes looking at the skid marks and examined his car closely, especially the tires and brakes.
It doesn't look like there's going to be any accident investigation since it was on a race track the DOT doesn't get involved. I was a trained aircraft accident investigator in the Air Force and have some knowledge of auto accident analysis. After reviewing my in-car video, examining the car and the crash site my personal "most probable cause" is a catastrophic right side brake rotor disintegration which caused the car to rotate left.
My in-car video shows a small "flash" from the right side of Cale's car that looked like tire smoke, but all 4 of Cale's tires were still inflated--I actually checked the air pressure. The car's right side brake rotors were both cracked which could have been caused by the impact, but the rear rotor was completely gone. The "tire smoke" could have been the brake dust and rotor debris from a right rear rotor disintegration. We did a sweep along the braking zone but didn't find any brake parts but BSR has been running training on the circuit. His brake fluid level was normal and all of his brake pads had plenty of material left.
If one of the right side rotors broke up it could have pitched the car into a left hand slide. The loss of a rotor can also allow the brake caliper piston to fully extend which would allow the brake pedal to soften or even go to the floor.
The skid marks at the track were easy to follow from about 50 feet from the edge of the track to the wall. The car was sliding with about 30-50 degrees of left yaw from on the track abeam the access road all the way to the wall.
The car's right side hit the wall pretty much flat against the wall while still in the slide. He didn't hit right front like I initially thought.
I now believe the car went to the left because of a brake failure, not because Cale was trying to take the access road to miss the tire wall.
All the safety equipment was intact. The seat, harness, and cockpit were not compromised.
After seeing the impact marks on the wall and seeing how much of a side impact it was, I realize how hard he hit and don't know if a head restraint would have saved his life, but it certainly wouldn't have made it any worse.
On another note, Brenda and I plan to be there Thursday and Friday for the viewing, ceremony, and reception.
Sad news, my prayers go to his family.
its scary to think about how hard some of us drive at the track at times. Time for a hans?
Sobering and sad. Never knew/ knew of the guy, but one hopes it was painless, and that his family is ok.
