Is there a way to permanently defeat the steering wheel lock feature? I'm looking at flat towing the car to and from local AX events and want to make sure the steering is always free to turn.
Flat towing so you'll still have to change tires at events??
More Better - http://www.drifting.com/forums/attac...s-mvc-013f.jpg
BTW, Miatamoto and I are considering flat towing my car to Nationals this year behind his X3, so keep us in the loop if you come across any tricks.
I think channelmaniac posted a "how to" a few months ago
involves a drill at the right spot on the column
I believe it is required for Spec Miata
Neal is right - search Specmiata.com and you should be able to find a how-to on there somewhere.
What about this setup Mark52 then you would only need to change 2 tires.
http://www.harrisonindustrial.com/im...0Day%20002.jpg
BTW. Stolz flat tows his Miata all over the country behind his RV, I'd bet he has some tips and tricks! ::Teacher:
an easier way that would not be as cheap, would cost $15 to $20, is to do what I did on my almost Spec car, the ex-Robert Jones red car
I got a big battery cut off switch from OReilly or similar for about $12
one with the big removable red lever
then got a 6" negative battery cable for $3-4
put the switch in the trunk near the battery ground location, and hooked the new ground cable to the factory location on one end and to one side of the switch on the other end of the cable
took the original negative battery cable and hooked it to the other side of the new switch
turn off the switch, and no juice anywhere
can leave the key in the ignition and leave it turned to the "on" position and won't hurt a thing
Check with the RV guys or Trailer World.
They can tell you how to rig just about anything to flat tow.
My dad has a Tracker and Jeep Safari he flat tows (a lot), and has lights and a brake set up for it too.
I believe he leaves the key in acc and in neutral. (Jeep's a slushie too)
Its the same thing you would do on a towdolly, but no dents on the doors. ;)
Just turn the key to the first off position and leave it in the switch.
Get a red tag to hang on the steering wheel to remind you of the key, tranny, and park brake. My Dad used to flat tow his VW. He forgot the brake and cooked it in just a few miles. His 'buddy' was following him and finally called on the CB to say the bug was smokin :(
Another trick is to tie a flag on the steering wheel at 12 o'clock to make sure the steering wheel hasn't managed to spin to full left or right lock. If it is visible through the mirrors on the tow vehicle, then all is well...maybe.
Drill the column in the right place and install the sheet metal screw and you'll disable it. Piece o'cake to do. I did it on my Spec project car.
DO NOT tow a Miata by a 2 wheel dolly unless you disconnect the driveshaft! You won't hurt the engine but you will toast the transmission. Something about the way the oil is flung about inside it and one or more bearings won't be getting oil. I forget the details.
When I towed my Spec project car home, I pulled the driveshaft out of the back of the transmission and left a nice trail of oil down the road until it all leaked out. OOPS. ;)
