How mandatory is the famous 12inch drill bit to put in a roll bar? I'm putting in a Boss Frog single hoop this weekend. Also any suggestions or tips not in the instructions?
Black and Decker makes an 12" drill bit extension that works for any drill bit up to 1/4" shank that holds a regular bit with a couple of set screws and sells for a couple bucks. Available at Wally World so it's a lot easier to find than a long bit.
Good idea, I don't mind buying tools, I just want to be able to use it more than once.
I bought a cheap-ish 12" bit for my roll bar install, and we pretty much ruined it after drilling the required holes for one roll bar. But, hey, it was only $15 or so... :rolleyes:
And, yes, you will need a long bit (or an extension) to drill the vertical holes in the rear deck. Your drill motor will not clear the roll bar down-tubes.
Home Depot sells the correct size bit. It's about $10 or so. Buy it and lend it out as needed for other folks installing roll bars. ;)
I'm pretty sure Westlake ACE has that bit, plus it is close to the house! ;)
Hurry up with the pictures already!
May not be this weekend, having an emergency at work! Ah yes, the best laid plans...
I may try just getting it mounted sunday then do the detail work through the next couple of nights.
Emergency over!
The seats are out there is no turning back..:drive:
I may put out an emergency call tomorrow!!
Are you taking it to the TDR@MSR event?
Nope, it would be a great first time event for me and sounds like a lot of fun while being very informative, but Mrs. Silver and I are heading to Tennessee for the in laws 60th wedding anniversary and will be gone for about 10 days. Besides, my Dr has not released me to even be driving a stick yet with my hand after the wreck (:rolleyes:Hay I have to get to work some how) but still I should probably not be out on a track.
Anyway...
OK the 99, is all stripped and ready to set the bar in. The only tragedies were two of the smallest trim fasteners, they will still snap in place, but a piece of the head broke off…no biggie.
Never having been involved in an install before, I’m assuming (oh-boy) that the drill points will be fairly obvious once I get the first bolt or two in. Mrs. Silver should be able to help me set it in, but everybody listen for a yell from the Basswood/Riverside part of Fort Worth tomorrow just in case!
I haven't installed a Boss Frog but I have installed numerous Hard Dogs.
If the Boss Frogs are anything like them, you want to do the following.
Before you drill any holes, make sure all the other bolts are in. Get each one started first and then torque them down after that.
Once all the existing bolts are tight, then you will drill the other holes.
+1...
If it mounts to the seat belt towers, then get that done first. I got mine that far by myself on a Saturday morning. Once you've got it nailed down there, then drill your holes and crank it down the rest of the way - you'll need a buddy for this part to back you up as you tighten those bolts.
Some pictures:
Getting started
http://forums.dfwmiata.com/picture.p...&pictureid=186
Stripped down
http://forums.dfwmiata.com/picture.p...&pictureid=187
Starting to look good
http://forums.dfwmiata.com/picture.p...&pictureid=188
This was an important test… The top still goes up and down!
http://forums.dfwmiata.com/picture.p...&pictureid=190
If you will excuse me, I still have some drilling to do.
Thanks for the tips gentlemen.
Ken
It’s been along day, but worth it.
http://forums.dfwmiata.com/picture.p...&pictureid=196
My new desk top shot.
http://forums.dfwmiata.com/picture.p...&pictureid=198
That looks great! I have one of those clearviews sitting in a garage waiting for installation. Is that the standard (hardtop) or the Maxx?
It's the Maxx. I'm still going to get padding and a cover, but there is lot's of head room.
It was my first install and it went pretty easy, the initial bolts lined up with no trouble. I was expecting the drilling to be more difficult than it was, they went like butta! The last time I drilled through sheet metal it was a Dodge Ram Charger, just a tad thicker! Over all I'm positive with the outcome.
It was definitely a two person job in some spots, Mrs., Silver was a big help, she used a socket for the first time, went at it like a pro!
Nice job! That's a really nice bar... looks like the view out the back is a little better than mine. ;)
I didn't buy the padding and cover either. I thought their prices were unreasonable compared to Hard Dog. The single side, self adhesive SFI padding can be bought locally (Smiley's racing) and I am going to try sewing my own cover.
http://www.smileysracing.com/cat/vie...530&pgID=1322+
Good tip on the padding. I have been thinking about only padding the corners and the area behind the seats, leaving the center open.
