Miata, meet ROB
As I have just spent all of my "car fund" (allowance given to me by the wife each week for car related stuff) on buying my 1991 miata, I'm trying to find relatively inexpensive projects to keep me busy.
Luckily, my wife understands my car obsession and has even gotten into fixing it up and actually demanded that we go buy a random orbital buffer, affectionately known as ROB. I'm just begining the VERY slow process of trying to smooth out the paint and get rid of all of the scratches and swirl marks that COVER this car's paint.
Since my budget is tight, we picked up ROB from walmart for $20 and some Meguiars Ultimate Compound. I've only done about 1/3 of trunk lid so far but I can tell it is working... slowly but working. I'm thinking I'm going to need more bonnets to complete this process. I've been using the wool one that came with ROB. Are there better ones out that that I should use? Any other helpful tips?
Thanks.
'Stickys are your friend'
I wouldn't use the wool for compounding it is better suited for polishing.
Get a bunch of the terry cloth bonnets and change them often. You can run them in the washer so they last a long long time. ;-)
1 Attachment(s)
Any DIY tips for this "blemish"
Polish it best ya can!
But I'm thinking you'll need a bit more than ROB is going to be able provide to make that "blemish" go away! ;-)
I know I need to get some "touch up" paint (huge understatement :) ) and some sort of filler... I've never done paint/body repair before. Is there something I can do on my own to get this filled in and painted so it doesnt get any worse? Can I just order my color code online...
Thanks again
Originally Posted by
MoonieGT
Slap a GT-R badge over it. :D
That's a two for one special, better looks and more hp!
http://www.properautocare.com/plmibubo.html Has anyone tried these out? I'm thinking about grabbing a 6 pack and some of the Menzerna Intensive Polish and seeing what happens...
Maybe rear mud flaps would cover most of it. :dunno:
or maybe
http://www.bulletholedecals.com/images/22phppic.jpg
Intensive polish may be more than you need. I got both Intersive and Final Polish II and the Intensive worked good on some trouble spots on my 'lac I also used it on the Red Miata but it was pretty aggressive.
(link - http://forums.dfwmiata.com/showthrea...tensive+Polish)
You can also find the microfiber bonnets at Wally World.
Save you pennies for a PC with the foam pads much better than a bonnet setup IMHO.
Thanks again POS. I'm saving my pennies for a laundry list of miata projects right now :) I want to improve the paint as best as I can (but on the cheap side for now). I need to spend my money on doing preventative maintenance items first. I don't mind putting some sweat equity into the car though. Attacking the paint seems like a good way to get me working on the car while I'm saving up for the timing belt/water pump kit. Not to mention I need a jack, jack stands, fluids, brakes, pads.... the list goes on.
Thanks again for all your help guys
That's perfect! I can add a couple of those to the right side of the car and get that balanced, symmetrical look.
Rogue
Just keep in mind that you can screw up the paint if you get overly aggressive.
I'll try to be patient and start with the light stuff first. Apart from the fact that you can tell the car is green, I'm not sure that I can make the paint any worse. It's scratch city on every pannel of the car. I'm not sure what happened to the poor thing...
On the plus side, it seems to run quite well for an 18 year old car with 182,000 miles.
You dont want to be polishing with abrasives any more than you have to really as it is reducing the amount of paint on the car every time you do it... It is not a limitless supply! ;-)
Be careful when using the ROB around the area this is not flat. The paint on the Miata is pretty thin and it will "evaporate" right in front of your eyes!
