Originally Posted by
POS Racing
Quick easy check of the condition of your a/c systems :
Mazda recommends the following procedure to evaluate refrigerant charge: 1) Run the engine at fast idle; 2) operate the air conditioner at maximum cooling for a few minutes; 3) determine the amount of refrigerant as shown below, by observing the sight glass:
If bubbles are present in the sight glass, there is insufficient refrigerant, and the system should be evaluated and recharged.
If no bubbles are present in the sight glass, this indicates either the correct amount of refrigerant, or too much refrigerant. If, immediately after the air conditioner is turned off, the sight glass remains clear, then there is too much refrigerant. The proper amount of refrigerant is present if, when the air conditioner is turned off, the refrigerant foams, and then the sight glass becomes clear.
