Originally Posted by
POS Racing
Also on Miata.net
Tim's description was good, but a couple of clarifications: Lubrication in a running transmission is more atomization than splash. The gears turn so fast that the oil is misted, not splopped around. So, if oil is splash or slopped around in a towed transmission, realize the lubrication mechanism is not only a different amount of oil, it is delivered in a different way.
Keith also makes a very good point regarding the load on the towed transmission. The heat, gear face pressure in a running transmission make significant demands on the oil to lubricate and cool the parts. It's not all about RPM. The towed transmission is transmitting almost no power, so its oil requirements are much less. If you can get away with towing a Miata, this is an important reason why.
As an interesting aside, the 6 speed has some of its synchronizers on the lay shaft. That is, turning the driveshaft does spin gears that are immersed in the oil. The 6 speed cars, surely, shouldn't have any issues with lubrication while towing. I wonder if Mazda made note of this and approved its towing? I'll bet not.
