What do they weigh, what tire size, and what rear springs and rear sway bar?
What's the lap record in one? I want to know when I can stand up to make #1 again.
My cars weigh about 2300 with driver, 350 lb/in rear springs, racign beat rear bar (or standard SM rear bar), 1:20 and change my personal record at MSR 1.7 CCW, but 21's are more realistic if everythign is perfect; can race solidly in 1:22s. In endurance trim for the 8 hour, we ran pretty consistent 1:58 at TWS on the 2.9 CCW configuration. Could go faster for sprint or qualifying on shaved tires (we used full tread tires for enduro)
Thanks. I'm, a little confused by your rear sway bar. I just put-in door bars and I have gross understeer. If you're stiffer and using that bar, then I'm doing something wrong.
I assume this is on an 8"-wide wheel with 205's?
Time to go buy 3-seconds of skill.
I currently run 225 45-15 tires. A bigger rear bar may help with push - it does for me.
