Originally Posted by
jeepinbanditrider
The mount setup will be a 3 gauge a-pillar pod and if I use or need the 4th the center driver's side vent. Or just get a two gauge pod if I use 3 gauges and use the vent anyway.
My 91 reads PSI on my oil pressure gauge it flucates in concert with Engine speed so I assume it's telling me correct readings. Does the water temp sensor mod use the stock gauge or do I need to get another one??
Would the more FI enclined here recommend the Fuel Pressure being a more important reading than EGTs?
