Video from MSR Cresson on the 3.1
Video from this past weekend. Best 3 laps of the weekend were all in the same session, within 4 tenths of each other, and within 4 tenths of the theoretical best lap from all laps throughout the weekend.
http://www.vimeo.com/14944357
First proving up of a DIY cool shirt setup - invaluable even with temps in the low 90's.
First weekend with a Spec II+ clutch, lightweight flywheel and pressure plate. Rev matching is much easier (though I still need to work on that), and everything winds up faster under power. (Thanks TDR for the parts and Rogue for the install!)
First weekend after a torsen LSD diff swap. Night and day difference in drive out of the corners with the car under lateral load. Wheel spin is gone but is replaced with some understeer. I think I'm going to have to find some alignment specs to make that go away. (Higher air pressure? Stiffer rear damper settings? Less rear toe? (1/8" toe in currently))
Second weekend on 205 Star Specs. Excellent tire. 32 psi front, 30 psi rear, set it and forget it.
Oh, and video + data is awesome.
Chris
