FAULT CODES ('90-'93)
1 Ignition pulse (No Igf signal)
2 No Ne signal
3 No G signal
8 Airflow meter open or short circuit
9 Water thermistor open or short circuit
10 Intake air thermistor in airflow meter open or short circuit
12 Throttle position sensor open or short circuit
14 Atmospheric pressure sensor open or short circuit
15 Oxygen sensor <0.55 V 180 sec after 1500 rpm
17 Oxygen sensor unchanged after 1500 rpm
26 Solenoid valve (Evaporative canister purge)
34 ISC Valve
so would a bad would a bad air flow meter cause cold start issues? i figure if that was bad then i'd have problems all over the rpm range, not just at idle on a cold start.
