My driver's side top latch is quasi broken. An have an extra one?
I have a set of latches off my old soft top I can part with, but I don't think they'll fit your NA... Rosenthal lists two different latches, one for 1990-2003, and another for 2003-2005. Mine are the latter.
Mine is a 99, but if they're 03 or later I guess they won't work...
Is it broken in that it won't stay shut? That's a common problem and a 15 minute fix with a screw with keep it shut. It's in the garage on m.net.
The tab that keeps it closed until you press the release button fracture and won't stay latched.
As Goofygrin said, if it is just worn, you can fix it. Here is a link from M.net showing the repair.
Linkie:
http://www.miata.net/garage/top_latc...0side%201s.jpg
I have an old set from my 94. Not pretty, but they worked when I replaced them with a nicer set. you can have them if they'll fit.
My mistake, I forgot the post where you got the '99... for some reason I thought you still had the old BRG.
Jiggerachi's is a good offer. Those bad boys ain't TCB friendly.
Tried to PM you about the latches. I'd love to give them a try. Let me know when I can come pick them up.
Sorry i;ve been busy with holiday stuff the last few days. It appears my subscription ran out and my inbox is over limit now. Email me at g r e m s t e r 3 0 0 0 (gmail, no spaces) while I work out the subscription thing.
