When doing the timing belt/water pump do the timing cover gaskets have to be replaced
I am gathering parts to do the timing belt/water pump - also hoping to try to fix the oil leak somewhere on the front too while I am at it, are the cam seals and front crank seals, valve cover gasket and CAS o-ring the only ones that seal the in the oil (besides the oil pan and head gasket), or does the timing cover gaskets seal in oil too?
Worst case if it is the pan gasket, can the oil pan be dropped with the engine in place?
