Signs of a bad/weak battery?
The more I notice things, the more I realize my car might have a bad battery. While my car is running, my oil pressure gauge will often randomly spike then go back to the correct pressure, and if I roll my power windows up or down it will spike up and go back to normal once I let go of the switch. My idle will also drop down quite a bit if I turn my headlights on, the oil pressure twitches when the hazard lights/turn signals are on, and every once in awhile my car will have a very jumpy idle. In addition, this cold weather sometimes causes issue with my car firing up on the first crank. I have to give it a second crank every once in awhile.
Would these be the signs of a dying battery?
