Source for Cheap Corner Weight Scales
<www.miata-power.com/race-car-scales> is the pertinent link.
Iain or someone might wanna post it to the other forums.
Chris
Forwarded Message
To: "Robert Mangas" <[email protected]>, [email protected], [email protected], [email protected]
Subject: Re: cheap corner weight scales
Date: Tue, 23 Mar 2004 06:44:18 -0800
HTML Attachment [ Scan and Download | Scan and Save to my Yahoo! Briefcase ]
Just heard back from the manufacturer...if I can get three (minimum) sets to order they'll give me 10% off each of them for the initial order. www.miata-power.com/race-car-scales In building my cage this year, I know steel has gone up about 40-50% since the first of the year.
I also am marketing the crank scrapers. Sent out my rod and piston to get a pattern made. Have a setup that bolts to the main caps so the pan location isn't changed. Works with the 1.8 either with or without the main bearing support plate in the '01 or later (two different designs). I have one of each and will see how they fit when I get to putting my engine together. See: www.miata-power.com/crank-scraper they have them for 160 different applications as well.
Chas
www.miatapower.com
[email protected]
----- Original Message -----
To: [email protected] ; [email protected]
Sent: Wednesday, August 22, 2001 6:20 AM
Subject: RE: cheap corner weight scales
How about a group buy for your first order?
>From: "Charles Cox" <[email protected]>
>To: <[email protected]>
>Subject: cheap corner weight scales
>Date: Mon, 22 Mar 2004 17:39:18 -0800
>I just found a supplier for an inexpensive corner weight system
>(mechanical). Is very simple and similar to the Ruggles' system I use (but
>better and less expensive). They have also been shown to be accurate and
>repeatable.
>I'm going to offer them for sale as a distributor...
>See: www.miata-power.com/race-car-scales
>Charles
>Charles Cox
>www.miatapower.com
>[email protected]
__________________________________________________ _______________
All the action. All the drama. Get NCAA hoops coverage at MSN Sports by
ESPN. http://msn.espn.go.com/index.html?partnersite=espn
