FM swaybar set $125
front and rear FM adjustable swaybars, sold in the pair only, $125. for 94-05 miata
though the swaybars are slightly different for other year models i understand they work fine on 94 and older.
Ultrashield Spec miata seat sold.
i stay in lewisville, will drop off or pick up.
oops, to clarify, the seat is welded to factory frame rails and the swaybars are intended for 94-05
how did you weld an aluminum seat to the steel factory rails?
the back half is bolted, the front half is bolted to a metal L bracket which is then welded either to the frame rails or the seat, i forget which. to clarify also, the seat size is a 15 or 16.
seat is sold.
still have Flyin miata swaybars, $125 for 94-05 miata
