Stealership suckage goes up big time...
Well,
The stealership up in Corinth is on my $#17 list now.
I'm having to take a day off work tomorrow to get the car looked at.
I had a small oil leak and was going to take it in to get it looked at. Well, it turned into a BIG leak when the drain plug dropped out of the oil pan.
One drain plug, one crush washer, and all new oil later... It's running, no funny noises from under the hood, but I do have a CEL.
VatoZone says it's a code for excessive timing r3tard on bank A.
Now I get to go kick someone in the head. :x :x :x :x
I want them at a minimum to put in a new oil drain plug/washer, wash the car - INCLUDING the undercarriage, and to check the oil pressure with a real gauge to see if it is now low.
Anything else you guys can think of that I need to make them check?
Re: Stealership suckage goes up big time...
It didn't happen when you were at Motorsport Ranch did it? Heck it was even leaking when you were over here Saturday.
