Do NB OEM Bumpstops last forever???
The rear ones on my 99 were all gone at 110K and the front ones were in OK shape. The rear one had very cheap foam like material and not like the front ones with denser rubber-like material. The ride was day and night difference once I put on the FC bump stops!
These only had about 50,000 miles on them.... Fronts looked fine as you mentioned.
Speed bumps in the parking garage?
Nope no speed bumps. You may want to check your car Onething.
Originally Posted by
POS Racing
I bet there is nothing there! Time to call FC for new ones!
Replaced them last night there wasn't even a trace of the old bump stop when I took it apart.
Did you use the FatCat bumpstops?
motorollow
Sort of same spec but lower price. ;-)
Reference - http://www.dfwmiata.com/threads/17159-Budget-Bumpstops
The rear bump stops in my rear MSM bilsteins looked like that until I swapped them out.
If you bought a set of the Raceland Coilovers, they come with new bumpstops already in place correct ?
