Getting ready to install new brakes and need advise/suggestions on which brake fluid to use and where to get it locally if possible. Heavy autocross use, plus regular street use...
Thoughts?
Thoughts?
A bunch of us have been using Valvoline for several years now. Get it at Vatozone.
http://www.valvoline.com/products/co...brake-fluid/28
If no track days, then no reason to use the high-dollar stuff.
I alternate between valvoline and ate super blue to make flushing easier.
So some vatozones in theory still carry valvolvine... good to know. thanks. mine officially sucks.
Prestone DOT4 seems to do fine for aggressive street driving.
I think the high the temp fluid the quicker it absorbs moisture. No race, no race fluid.
I'll be the voice of dissent here. Imagine that. ;)
I've tried the Valvoline stuff and it's what I use in my wife's car, but I prefer the pedal feel of Motul RBF600. The Valvoline seems to have slightly more compressibility, which translates into a slightly softer pedal feel.
FWIW, Cobb Tuning carries RBF600 if you're looking for a local source.
I use Ford HD Dot 3. About 590*F dry boiling point, available at Ford dealers and TCB approved. Wet BP not so good, so change often.
Thanks, guys - I really appreciate the input. Goin' with the Motul RBF600 - getting it from TDR, and William is providing EXCELLENT customer service by letting me pick it up from him in my area!
And I am planning on a track day or two...Phil has convinced me.
Well worth it if track days are planned. I never had any fade after I switched to the Motul
I have Motul in both the autocross and track Miatas, and the Z06 with WilWoods
no issues at all in any vehicle
previously used the Valvoline Syn (2002 or so) in a Z28 on PCA Time Trial, and first time I ever had fluid boil and zero brakes till cooled some
nursed the car home and flushed that stuff out minutes after arriving safely -- never again
the ultimate is Castrol SRF, but last I bought was $70 a quart
Chris -- PM me if you are interested in an Apex track day
Thanks Chris. Glad to help. I know you will like the Motul and haven't experienced it absorbing moisture and quicker than the valvoline. Not a fan of the super blue as it stains the reservoir and is not DOT legal IIRC. Besides, is it really that tough to see the difference between clean and dirty regular brake fluid?
Castrol LMA keeps it's color better than any other fluid I've used and it's cheap. I use it in my daily and both clutch master cylinders.
