Lubing power window channels and cable.
Took apart my drivers side door to lubricate the window channels and see if it'd make a difference in speed of raising and lowering the window. For this side, there wasn't really a difference. Maybe there will be on the passenger side when I get around to it.
Things I found out were that there isn't a ton of room to work with, but it can be done. I even went through the trouble of removing the old somewhat crusty lube first. That was probably the biggest pain of the project. Lots of paper towels and mineral spirits followed by more paper towels.
I used silglyde (however it's spelled) from Napa. I avoided the spray grease that is most commonly recommended because its spray gets all over. Thankfully my fingers are small enough to get into the channels (just barely). Lubed the rear and central metal channels, and the rubber front channel and regulator cable.
The biggest ANNOYANCE, was the stickiness of the plastic rain shield sealer.
Anyway, I didn't really get the extra speed I was hoping to, but I can rest a little easier knowing its all got fresh lube.
Regards,
piff
