Something electrical is wrong.
So, I was planning (still am) to help a friend of mine fix up his 95 Miata (a/c, no abs). I was thinking it would be mostly cosmetic stuff, but then the alternator went bad, so I replaced that and now everything is wonky.
Existing condition, driver side headlight doesn't go up and down correctly, the positioning is always off when you can get it connected to the arm that rotates it.
Basically, I replaced the alternator, got it all put back together and everything seemed fine, started it up, sounded a bit loud. I put the clutch in and everything quiets down a bit. Then I put it in gear and right as I let the clutch out, the headlights turn off, the dash backlight gets brighter, and the windshield wiper turns on (in off position).
Also, the headlight motor on the driver side was incredibly hot when the car was running and smelled like it was cooking itself.
I'm planning to check all the grounds, but I just wanted to see if anyone has any suggestions or has dealt with this before.
