Shifter not aligned correctly
Did the 2 shift boots on my car yesterday. Both were badly ripped.
Now that I've replaced them, the shifter doesn't seem to be vertical in neutral. More forward and to the right.
Besdies the fact that I ripped the outer boot by accident when I put it on, did I mess with something in the transmission to cause this? Shifter looks seated correctly at the inner boot. I did notice when I put in the shifter I had trouble aligning the bottom plastic piece into the transmission. Could I have knocked that metal sleeve piece out of alignment? If I open everything back up again can I move it with my fingers to try to make it straight? I made sure the turret bolts were nice and tight and just slightly tightened the back 2 I could reach.
Thanks in advance.
