Car won't start! HELP!!!!
Aright I dunno what I did but I bought the 30k mile tune up kit from GO miata and installed the plugs and wires on my 93 and now it wont start. I've checked the firing order a thousand times to make sure and its all correct. I crank it and it tries to start and sometimes it almost does but no dice. It also smokes out of the engine bay a little bit. The thing is it was running fine up until I changed the plugs and wires. Oh also the valve cover gasket was leaking oil down into the plug holes. So I changed the gasket...since oil down there isn't good. I figured that maybe some oil got down in the cylinder and was causing it to not start. but I looked down in there in the hole and there wasn't really any oil in there. So today I'm going to check the fuses and make sure none of those are blown. If anyone has any advice please let me know. Thanks
Matt
Re: Car won't start! HELP!!!!
Matt
What are you using as your reference the Haynes manual is wrong for the 1.6. :wink:
http://www.miata.net/garage/images/TBELT11.JPG
More stuff here = http://www.miata.net/garage/ignition.html
