I need the factory bracket that holds the vacuum servo down. Just noticed mine is broken. Anybody got one?
Buy me the relocation bracket and you can have my factory one.
Hmmm... how much is it? Does TDR have them in stock?
Actually, I should probably get the relo bracket since my cruise is relocated...
Darn, I was hoping to get a relocation bracket. ;-) The relocation bracket looks like a metal strap or bar that should be easy to fabricate.
Did you buy that C.C. from me? If so, then it is possible I have the factory part laying around. I have no idea what it looks like so I would need a picture if you want me to look for it.
Yeah I got that from you but I took the bracket. When I swapped intakes, I moved the module back the shock tower and sawed off one leg of the bracket to bolt it in. It finally fatigued to the point that it broke.
I may go get a metal strap and try to fab a bracket, but I'll check with TDR first.
I just zip tied mine after installing the RB intake. Bailing wire might have been better!
Weed Eater line might just do the trick also. I've seen it done before.
I made a ghetto-fabulous mount out of some POS erector-set piece of metal that I bent into a half-ass "ELL" and drilled some friendly holes in. It may not last past Hallett, but the SOB will at least make it there!
