Originally Posted by
EricJ
Looking at the color of that brake fluid, if I were you, I'd do a complete brake fluid flush. Is the clutch fluid the same color? It should be almost clear. Think Sprite, not Coke.
Brake fluid changes to that color when it collects water. Water will do 2 things to your brakes:
1. It will rust brake components.
2. When it gets hot, 212 degrees, it boils and turns into a gas (as in non-fluid). Gas compresses easily, brake fluid is not supposed to compress easily.
Get a 3 or 4 of small bottles of brake fluid. I use the TrackDog bleeder kit. It's easier with a helper.
