Open track Suspension HELP!!!
I really foobarred my suspension setup for open track and I need some input. If I would have been more rested I would have come to my senses and mde changes at the track but I was too tired from battling a rear caliper to tackle a suspension change at the track.
Here are the basics of my setup - Please don't laugh. I did not put it together.
Stock Springs
Koni Yellows - Set on the lower perch in the front, Upper perch on the rear
Racing Beat Adjustable Sway bars set to full soft in the rear. Full soft front.
Badly worn Rock hard Yokohama A008 195/60/14 on stock 5.5 inch rims.
The car is rolling badly. In heavy cornering, the front tires rub on the ABS plactic wheel well. The tires are wearing fine on the street and the alignment seems fine for street, however, at the track the outer third of the tire is wearing much faster than the rest of the tire.
The car is understeering.
Picture of the car loaded in the corners show it almost on 3 wheels and badly rolled over. Weight transfers seem slow.
My initial thoughts are:
1. Stiffen up sway bars
2. Soften shock settings
3. New tires are a given (but do I go with 195/60 or 185/60 to avoid the rubbing)
Spending additional money
1. Stiffer springs
2. KYB 8-ways
What are your thoughts
Re: Open track Suspension HELP!!!
1. Stiffer springs
2. KYB 8-ways
Before I started spending money on parts, I maximize what you've got on the car already. Start by running that front bar at full stiff, and getting a decent performance alignment - there have been plenty of threads on alignments here, so search the archives.
That, and a new set of tires (I'd recommend Toyo RA-1s or Kumho Victoracers for a primarily track car) ought to make a huge improvement.
