tie rod end bolts on steering rack
I'm in the middle of a PS depower job and I may have screwed the pooch. I had to pull the rack before cracking the big bolt that connects to the tie rod end...the big bolt with the metal keeper on it (not the castle nut on the hub, the bolt under the boot.)
Anyway I had the rack in a vise, with a wrench on both ends, the passenger end keeper chewed up and the bolt on that side backed out. So now I've got the shaft spinning freely. I wrapped it in a towel and put the shaft in the vise directly, but I can't get the vise anywhere close to tight enough on the shaft to allow the other bolt to crack without rotating.
Any ideas? Is it time to go to the junkyard and try again? At least i've got the pinion out I can go drop it off at vorshlag while I figure this out... :punchout:
