I'm looking to by several used parts for a 1991 NA:
Red drivers front fender
Red drivers door
OEM or aftermarket stereo, cheap and functional is all that I require.
Rear shocks
Rear zip-out window section for a black soft top. (Will take ANY plastic rear window in decent condition, zip out or not. I plan to do some surgery on the existing top, so any intact plastic window will do. If you've swapped your top and still have the leftovers, please let me know.)
NA power steering rack with tie rods and ball joints in serviceable condition
Cupholder or ashtray insert; need to fill the hole with something.
If you have removed your airbag, I'm interested in the blue module(s) that are located on the steering column under the dash. Trying to chase down an airbag code.
I'll add more to the list as I discover what else might be helpful.
