Any interest in a "low mileage" NA roller?
Before I go getting pics and try to remember all the little extras I'd include, is anyone even interested in a 1990 shell with only 102,605 miles on it? Or should I go straight to Craigslist?
Quick details:
-Silver. Paint isn't terrible, but it's not near great.
-Top is original, window finally cracked two summers ago. Still in better shape than quite a few tops I've seen still in use.
-driver seat, cluster hood, both door windows are missing. Door panels have a hole cut in each for tweeters. All speakers and head unit pulled.
-Rear finish panel missing
-Rust on driver rocker panel. Quarter panel was replaced way back in 2003, and the body shop didn't drill the drain holes. Started rusting from the inside, but I drilled a hole and coated the inside. Hasn't gotten any bigger in a decade. Not as bad as some cars I've seen on the road (no holes through the panel).
-55mm radiator, used NB shocks/springs (unknown mileage), MS motor mounts, some other random goodies.
-No drivetrain or ECU (except the trans, I will include the perfectly fine trans, but no clutch), but there is a 1.6l motor still installed. I blew the head gasket, but kept driving (I was angry), so it may need some work, or just a gasket. I have a spare motor and a spare head if wanted. I'll gladly remove the motor if it's more of a pain for you than an extra part.
