NA- 90-97 Miata power window motor and regulator, pass. & driver
Fully functional power window motors(driver and passenger) and regulators for 90-97, $150 each or $290 for both (obo) plus shipping. Driver side was removed from my '97 because I thought mine was bad but after installing one I got from The Parts Group and it was still sticking, I realized the guides needed adjusting and then it worked fine.(Check your guide alignment first!)The passenger side is from The Parts Group and didn't install after realizing the passenger sides problem was the window switch.254-721-4748, Chad, please use common sense and courtesy in regards to contact time(I'm Central standard time). Thank you!
