FS TrackSpeed brake hose kit used
For Sale
Track Speed brake duct kit that uses two inch hoses.
http://trackspeedengineering.com/pro...roducts_id/118
I bought the kit with the hoses included and used it for a couple of months.
I made air inlets using 2” tail pipe welded into a hole in a small sheet metal plate. It bolts in the upper corners of the Miata radiator inlet area. Not pretty but painted black and very inconspicuous.
I later went the supercharged route, and removed the air inlets due to blocking all of the space on each side of the intercooler. Need all the air to the radiator I can get
Caveat again is they are two inch diameter, not the larger 2 ½ that other kits use.
$80 cash, face to face, meet at an autocross or I can get them to someone who lives closer to you than I do (on the Stephenville side of Granbury).
