Engine cut-out: Please help!
My usually reliable Miata is letting me down! Can any of you guys help in tracking down the problem?
I have been on the freeway twice today, doing around 70, when the engine starts to faulter and loose power. It seems to start missing on just 1 cylinder and then it spreads to others and progresively gets worse. I have to pull over and the engine will not run after 30seconds of doing this. It then will turn over, but not fire and re-start. After 15 mins it will fire up as normal and acts perfectly. The engine warning light comes on, but oil pressure was good and it did not overheat. Neither was anything leaking out the bottom.
I'm taking it into the Mazda dealer tomorrow, so I can check out the engine fault code, but have any of you guys had this before? Any suggestions on what I can try investigating would be greatly appreciated!
Many thanks
Luke
