Found the Video on YouTube on replacing the antenna mast.
Is it as easy as the king makes it look?? ;)
Sounds like I'll be dealing with just a bent antenna mast and not a broken leader (yet)
We really need to get a costume for Rogue and start recording.
Fyi - I am thinking gabkwong has a spare NB antenna. You might check with him.
I've got a rubber ducky antenna if you want it. It came on the car (from a previous owner) and I preferred the OEM so I picked up one from Track Dog.
^I'll take the rubber duck if POS doesn't want it.
Thanks for the offer cwiesenheimer but I plan to just fix the power antenna at this point.
I intend to install a shorty at some point. If a perfectly straight and working pwr antenna from a NA will work...
My answer to the original question is yes. I replaced mine a few years ago and it was that easy. IIRC, I bought the new antenna from MMD.
I took my power antenna out from my NB out if someone needs one?
Did EKK break her antenna? You can't buy her nice things.
Got a new antenna mast in this morning from Brown Santa. Watched the King of Miata Video again. Ran out to the garage and in under 10 minutes had it swapped out.
Was a very easy fix!
