1992 Interior lights question
Hey guys/gals, I had a quick question about an issue that I'm having with my interior map (?) lights in my NA. Im referring to the lights on each side of the tombstone. Last week I noticed the light on my drivers side and had gone out. So today I went ahead and replaced the bulbs on both driver and passenger side with some LED's to get some actual light in the car. Passenger side went smooth, but after fitting in the bulb on the drivers side I noticed it wasn't fully working. By that I mean, the light would only come on in the "door" position, and not in the "on" position. It would flicker here and there, but ultimately would not come on. It was flickering some even in the "door" position, but I eventually mounted it back into the dash with it working properly in that position. The wires seemed fine, and the LED was placed properly. I thought it might be the bulb, so I swapped in the pass side bulb (knowing it fully works), but the same results showed. My guess right now is that it could be a bad fuse? But if it were the fuse, then that light wouldn't work at all, even in the "door" position. Yeah? I'm just looking to see if any of you have had this issue, and if you were able to fix it, along with any other ideas you may have.
Random google image below so everyone knows which lights im talking about. Thanks
http://carphotos.cardomain.com/ride_...0004_large.jpg
