6 Attachment(s)
For Sale - 2500 dollars AUTOMATIC NA6 (A) package
I am getting out of the Miata world, going back to motorcycle riding after a 3 year break. I wanted to offer this car to this forum first as I have purchased parts from many of you here.
For sale is an AUTOMATIC White 1993 NA (A) package 1.6L. 167K
Water pump, timing belt and antifreeze were changed less than 1k miles ago.
Everything listed below has been done to this car over the past 2 years with the exception of the timing belt/water pump. I would feel safe letting my teenage daughter drive this car if she was old enough.
This car passes vehicle emissions testing every year with flying colors. This was a daily driver until I bought another bike.
Starting from the front.
Engine stuff:
Timing belt, water pump, antifreeze and Plug wires/plugs >1k miles ago
Head and gasket replaced 3 years ago.
Radiator replaced
All hoses replaced
CAS replaced
Throttle body and sensors replaced
Transmission fluid and filter
Transmission vacuum module replaced
Factory exhaust/catalytic converter/muffler replaced
New AGM battery, less than 3 months old
Body Stuff:
Cobalt headlights
Vinyl top/glass window/rain gutter
windshield replaced
"R" package lip front/rear
Mud flaps front/rear
Factory "Daisy Wheels"/tires
Altezza tail lights
Electric automatic retracting radio antenna
Luggage rack
Tasteful rear spoiler
Boot cover in excellent condtion
Car cover included
ALL exterior lighting is LED except headlights/driving lights
Interior courtesy lights are LED
Dash lights are factory, no modifications
Suspension:
Factory springs, shocks replaced
NA8 brakes and rotors front/rear
Factory end links replaced
Factory sway bar bushings replaced
Interior:
Seats re-upholstered
dash replaced
heater core replaced
eclipse vents
AC checked/works perfectly
blower motor replaced
The negative about this car:
Before I purchased this car the previous owner did not utilize the battery hold downs. This resulted in the battery going air born and putting 2 dents in the right rear of the car, one above the battery, and the other on the side above the marker light. Nothing serious, minor cosmetic. I have replaced the missing tie down assembly. Local body shop estimated repair at 400 dollars. It wasn't worth repairing to me.
Oil leaks: oil pan gasket leaks a bit, but not enough for me to worry about. No leaks in automatic transmission.
For the firm price of $2500 dollars the following Miata items go too.
Complete set of control arms with energy bushings
tie rod ends
energy diff bushings
Everything you need to rebuild the suspension when it needs it.
extra factory console and automatic shifter
extra brand new AC compressor/clutch for 91-93 NA's (being prepared, lol)
Please PM me, or email (helmking at yahoo dot com) to see pictures or to view this car or ask any questions. Phone number will be sent to SERIOUS inquiries only. (located in the DFW mid-cities area) Thank you for your time and consideration.
