Solo Event #3 at Texas Motor Speedway Bus Lot - 5/21/17
Preliminary Run/Work order has been set. Based on the current entry level, there will be a 4 heat run/work structure. Any changes will be announced at the mandatory 9:00am Drivers Meeting held at the Timing trailer on the day of the event.
Run 1 / Work 3
AS, BS, ES, STR, STU, CAM-T, CP, EP, SM, BM, CM
Run 2 / Work 4
FS, HS, ASP, BSP, DSP, STX, CAM-S, BP, DP, SSM, DM, EM, FM
Run 3 / Work 1
SS, GS, SSR, FSP, STP, STS, CAM-C, HCR, XP, FP, KM, W
Run 4/ Work 2
CS, DS, SSP, CSP, ESP, STF, HCS, SMF, AM, FSAE, X
Course Map:
http://texasscca.org/images/2017_cou...017_E3_TMS.jpg
See you at the event!
