Building a homemade intake
Just curious if someone knows where I might find some aluminum tubing for making a home made intake for my Miata.
I have one right now but it's right above the Header and I want it on the cold side.
May even route something to the front air dam.
I will most likely use the cone from the one I have now and clamps rubber gromets etc.
Was thinking something like the Racing Beat design (kind of an S shaped elbow).
Here's an idea,...would it be possible just to attach the rubber gromet, a hose clamp and the cone on the throttle body?
I would think that might work too, correct me if I am wrong.
The only thing is I need to find a way to get the plug in... on the cold side.
I would need a source for some rubber hose too, so I don't trip a code.
That happens all the time now because I have the wrong hose going into the intake I have and it pops out from time to time, then the check engine light comes on.
I would appreciate it if someone knows a place I could buy a hose and aluminum tubing locally.
Thanks.
