wierd problem... posted this on the pointy board too....
Ok. I blew up the motor in my 2000 and have replaced it with a reman shortblock from a protege.(wanted the lower c/r) I also replaced the fw and clutch with a Fidanza and ACT HD. The car ran well for the first 300 miles, but I am having issues with it dying when I press the clutch in recently.
I cleaned the throttle body when the engine was out, and have adjusted the idle (10/grd), but I am still having the problem. I can be driving down the highway and just slip the car out of gear without using the clutch and it idles fine, but if i press the clutch in it wants to die.
I have read about the clutch switch, can I just bypass this switch to test if it is the problem or is there another route to try? Seems like if I jumped the switch it would cause the problem to happen all the time...
I think the clutch is fully disengaging b/c I can drive down the highway and step on the clutch with it in gear and the car wants to die. I would think that if the clutch wasnt disengaging that the drivetrain would keep the motor revs up...
It is a little frustrating b/c I have a whole new engine to trouble shoot instead of just a new part or two...
Any Ideas?
Also, this is a BRP gt25r turbo car.
