Hey guys, nice board, my fathers 96 Miata has the following components not working:
Tackometer
Fuel Gauge
Water Temp
Oil Pressure
Cruise Control
They all stoped working at the same time, if you have any ideas, please share.
Tackometer
Fuel Gauge
Water Temp
Oil Pressure
Cruise Control
Did you check the main fuses/relays under the hood?
Yea, its not fuse..any other ideas?
This sounds awfully familiar...
Perhaps the wiring harness is disconnected somewhere...
Should be something simple like a fuse or something disconnected, but if worst comes true Mazda Haven had plenty of 94-97 dashes and guage clusters last time I was out there.
Welcome to the board, Mark.Quote:
Originally Posted by mm84
Hmm... came across something that might help you in this other thread:
Originally Posted by gene501
Sounds like this might be your problem - I can't imagine another reason that those five things would all stop working simultaneously, except that somthing has come unplugged in the harness. This sounds like a good place to start.
I had that problem on my 96 last year and it was a fuse under the dash. It turned out to be a short in the reverse switch on the trans so every time you put it in reverese no gauges. I replaced the switch and all is fine.
:scratch:Quote:
