3rd gear grinding on downshift
I have noticed recently that sometimes my tranny will grind while down shifting & sometimes putting it in reverse. The other day after a long drive on the freeway I discovered it would grind on every 4th to 3rd downshift over 40mph, but it would not grind at all below 40, no other gears would grind on downshift, upshifting is & has always been smooth. Going to work this morning I could not reproduce the grinding over 40mph, but I dont think the issue is solved.
Any idea of what might be causing this??
I just put a fresh batch of mobile 1 gear oil in it about 4 months ago, & I havent seen any spots on the ground, but I have been smelling a slight oil burning smell after a long drive, a smell I have not had since I fixed the leaky CAS. Maybee theres a small leak thats just burning off on the exhaust, but maybee not bad enough to be leaking? The smell could also be on the same timeline as the grinding...or that could just be in my head.
Would low gear oil cause grinding on downshifts?? At any rate im going to check & replace any missing gear oil this weekend, I just hope this dosent mean $$$, because as of this month, I have none(moving into a house).
Thanks guys.
