Lately i've been having trouble closing the trunk, and yesterday my remote didn't even work on the trunk.
Anybody familiar or has dealt with the trunks on an NB?:confused:
I believe that you can disable the remote release on the 01+ by turning the key counter clockwise. Is it possible that you disabled it by accident?Quote:
Originally Posted by Mouglie
Turning the key counter clockwise on the '01+ (or "fixed" '99+) LOCKS the trunk. Nothing but the key will open it.Quote:
Originally Posted by Titus
I would pull the interior trim and take a good hard look at the lock mechanism. Make sure nothing "looks" broken. Clean and lube wherever you can and see if that helps. It may be helpful to have a friend with a same year Miata nearby to compare parts.
hey kool, thanks, i just put the key in and that the remote works now. i thought maybe the remote ran out of battery but it was just that lock. Well now the remote works so the opening part is good,
now i just need to work on the smooth closing. That thing will shut only when i slam it. Quite frankly i'm avoiding opening the trunk until i have a day off work just to pull it apart and see whats blocking the latch.
well some kool guy from the LSMC helped out with the latch problem, he recommended me to put some washers on the loop part from the trunk that goes into the latch, that worked really good, now my trunk is normal again!!!
