Well I cracked the crap out of the rear window yesterday.
Any TCB deals on rear windows? I have a Roll bar so I dont think glass will work. I am also looking for installation.
I'm in the same boat. Hopefully someone has a good hook up.
Try your local auto upholstery shop... They should be able to glue/sew in a new window.
I just picked up the proper Vinyl and Adhesive on line. I should have enough for two back windows if you are interested in replacing it yourself.
Sounds good! Where do you live? I'm in Mansfield.Quote:
Originally Posted by Screamin'Screw
Frisco - It would probably be cheaper for you to order it yourself since you live so close to Mexico!
TAP Plactics.
Did you get one sheet (22"x52") of the 40 mil vinyl and a tube of the 634 adhesive?
Yep!
:confused: So you guys are talking about gluing in a new rear window, instead of having one sewn in?
BTW, Mansfield is a lot further from Mexico is than Frisco is to OK.
Yep, maybe we should go in on this together since you're on my side of town.Quote:
Originally Posted by TurboDuane
how well does it work? Have you seen one that has had this done? I have concerns, due to the rollbar I don't unzip my window when I drop the top, so the window has to bend over itself. My concern is weather or not the adheasive will hold the window securely and weather or not it will look good or not.
