Anyone have an opnion on the best pace to get some minor soft top reparis done here in the Dallas area? What are the best reputable shops?
Thanks!
Thanks!
What is the issue? I fixed a small tear in my top with the help of Sammm, and I know others have too. A patch and the right adhesive can save a lot of cash. Someone else probably will chime in with shops though.
Edit: Welcome to the Board also!
Dee Trim Shop in Plano does great work.
I still have that adhesive. What's the issue with your top? Welcome aboard!...what part of DFW are you in?Quote:
Originally Posted by Majik
I second the recommendation... not the cheapest, but they do very nice work.Quote:
Originally Posted by JDMClassic
Thanks for all the responses! I am located in the Denton area. The issue I need to get corrected is the stitching on the edges of the top on each side back by the plastic window. The stitches have pulled out and the edging is coming loose. The missing stitches are on the back edges of the top not the actual section that contains the window. It seems like it should be relatively easy to stitch it back. Thanks.
V.O.R.A. in Lewisville did a top notch job installing my replacement top on the 92 B&T I used to have... While I was there scheduling the installation, I got to poke around a nice 71 Mustang that he was redoing the interior on. It was SWEET!
Go get some heavy duty thread and a needle and restitch it yourself, I did this on my '92 and it worked great! It's time consuming but worth the effort!Quote:
Originally Posted by Mach 5
Welcome to the board. Maybe I'll see you around Denton sometime :D
I took the advice of POS Racing and got some heavy-duty tan thread and re-stitched it myself. Seems like it worked very well, you can hardly tell it was re-stitched. It took about 30 - 45 minutes to do both sides and only cost $3.00! Thanks! :D
Spent $3.00, you'll fit around here just fine! :DQuote:
Glad the needle and thread method worked for ya!
Very nice!
give Jay's a call in Denton off of South Elm they do good work and are pretty cheap.
What?? :confused:Quote:
Originally Posted by driftdevil
Originally Posted by Mach 5 earlier in this thread
::BigWhack
Good job! Nothing like doing it yourself and saving big bucks!!! :clap:Quote:
yeah yeah yeah I know I'm alittle slow today:rolleyes: :burnrubr:
Hey 3Bean - we need a short bus smiley for driftdevil!Quote:
:nutkick: ::Assassin
::Bus::
If some of these smilies look strange to you fellas, it's that IE6 doesn't like the PNG24 format I'm using for transparencies...
Firefox, no problems.
