Would a misfire in a Honda cause the whole car to shudder?
sure!
Bastard. ::Fist::Quote:
::Daisy::
When was the last time ya did cap, rotor, wires, and plugs??
Wires and plugs at the second to last oil change.Quote:
Cap and rotors is another story... I'm gonna pull and check the wires and plugs when (or better yet, if) I get home tonight.
Sounds like it's jealous of all the attention you've been giving the BUR lately. ::Clown::
Yea rip it's dash out maybe it will feel better! ::Curls::Quote:
Could you have gotten some bad gas? (The car not you)
Has he been eating in Grapevine again?Quote:
I don't believe so.... we hit the same Chevron every time.Quote:
Nope... perhaps this weekend! ;)Quote:
I pulled the wires and found oil on the ends ... damnit.
I pulled the plugs and the ends were drowning in oil... double damnit.
Nah... sounds like a vc gasket.Quote:
Yep... was a common problem on my Civic. Especially getting the seals around the spark plugs to sit just right.Quote:
It's still under warranty isn't it just take it back to the dealer! ::Clown::Quote:
Quick! How do I remove the valve cover without prying in between the mating surfaces? I don't want to mar either side....
Forget it.... I beat on it with a rubber mallet and it finally moved enough so that I could get my fingers underneath.
I'm wondering what your keyboard looks like after using them oily fingers on it???
Not too bad... I've got a PC in the garage for these instances! ;)Quote:
Originally Posted by Darron65
Well, new plugs, wires, and a valve cover gasket set seemed to have solved the issue. I also went ahead and emptied out about 1/2 qt of oil thinking perhaps I may have overfilled the other day during my oil change. I'll monitor the oil level and wires to make sure this won't happen again.
:cheers: <score!)Quote:
