Popping sound - ?backfire?
'97 103K miles. I bought it a year ago at 88K. It's been maintained since then, but the prior history is pretty much an unknown. Physical condition is reasonably good.
Any diagnostic help would be appreciated.
My 97 is sometimes making a popping sound sortof like a soft backfire. The sound has an "in-a-tin-can" kind of sound to it. Almost like a cough in the muffler. the sound definitately emanates from under the car and well behind the driver position. The sound is not clearly on one side of the other that I can tell.
It is not related to engine speed.
It is not related to clutch-in or out.
It is not related to coast or under power.
It is seems to happen most often when the vehicle is cold.
It is definitely related to physical movement of the car: going over a rough road, it pops a lot.
It doesn't pop when the road is smooth.
It stops popping when the vehicle is thoroughly warmed up. (Note: I get good n' hot air from the heater long before the popping settles down).
The amount of popping is variable even more than described above, in that this morning (42 degrees), the amount of popping was moderate, but yesterday, going home around 6pm, I though parts were going to fall off the back end because it was popping so much.
I drove it over to pronto muffler today (18th & 75) from near 10th & jupiter and it was popping moderately most of the way, but by the time I got over there, it had toned down quite a bit.
I had the exhaust system looked at & the guys put it on a lift, listened for leaks, shook the exhaust train with the engine running & pronounced the exhaust system healthy. They suggested that if it was a backfire, it must be coming from the engine & I should go to a mechanic.
As I drove off, it was still popping a little. I got back to old downtown plano, and it popped once or twice as I drove in to the mechanic. When the mechanic got in for the test ride, of course: no more popping. So, no diagnosis.
FWIW, _I_ think the exhaust started smelling odd a few months ago.... almost like there was leftover fuel in it. In fact, I even went looking for fuel leaks. The fuel smell has mostly gone away, but the exhaust still smells like there's some alcohol or something in it.... just odd, to me. I have *NO* idea if that's related, but I guess it could be.
Any help appreciated ..... I'm just trying to get things back to normal.
Thanks
