Originally Posted by
trickyrix
OK... this is a project car, I'm not gonna lie to you. But here's the rundown:
1979 Honda Accord 2dr
I bought this car as a pet several years back. The previous owner had started setting it up for auto-x w/Koni shocks along with stiffer springs and big sway bars. The engine is unusual in that it has a Canadian-spec head (no CVCC valve). It's got a hot cam, twin Webers, and a full-length header. I drove it for a little bit after I bought it, and it's a fun little car. Anyhow, it had a slight rod knock, so I pulled the motor and rebuilt it (had everything cleaned up and the cylinders bored 0.20 over, all new bearings, pistons, rings, etc). At the same time, I had the flywheel machined and installed a new clutch, along with a timing belt, water pump, and accessory belts. Unfortunately, it has some kind of gimpy centrifugal distributor which I was never able to set. As such, the car never ran after I got it back together. It really needs a new home, as I can no longer give it the attention it (probably) deserves... that, and it's been sitting in my folks' driveway for a while and they're tired of looking at it. :rolleyes:
Anyhow... if anyone's interested, let me know and I'll go take some pix of it.
